front suspension noise
TDI 300
hello everyone, good to join the forum, n way i have got a rr td6 HSE, and there is a noise on the front left side of the vehicle, like a bush is damaged. i have replaced all the ball joints, and front arm bushes, the stabliser link is fine, everything is fine, but on hiting a *** hole or small bump, the sound is still there. please advice thanks.
Not sure what model year you have, but I would say a bad shock absorber.
TDI 300
fixed it but dealer.....
hey joey thanks for replyn, well it wasn't the shock absorber it was the front left elbow arm which has got a permanent ball joint attached to it, well after a few weeks the noise came back again. i then took it to a landrover dealer and they suggest they replace all the suspension bushes which is quite costly about 1000pounds. i told them what the problem is but they still suggest the same, oh the model is a 2002 HSE
Have you thought about doing the work yourself, or finding someone other than the dealer to do the work... you will save a lot of money
