A
AaronATX
Howdy. I have a 1998 LS ( but with all the LSE options ) disco. Bought it with 22k miles on it, and she's just turning 70k this week. Overall the car has given me very few problems, even tho I dont treat her like she deserves
I am at a crossroads now, as I would like to keep the truck but the costs of maintaining it much further will be prohibative, I fear. So without further ado, my questions!
OEM Parts:I am continually blown away at the price of everyday replacement parts for this thing. My fan clutch went out a year ago and the dealer quoted me ~ 200ish dollars for a new unit. I did some scraping around and found one off a wrecked disco for $60. Now thats more like it. I'm sure you are all familiar with this frustration, so what are some good online stores to search for new or used OEM replacement parts @ less than dealer costs?
Aftermarket parts: I am a gearhead by nature (been building/racing/breaking/crashing 5.0 mustangs since I was 17) and if I am to keep the truck i'll most likely be modifying the suspension and engine along the way. Can I get a few suggestions to online stores that cater to this type of part or any other forums you may know that discuss similar topics?
Shop manuals: Is there a haynes, or chiltons manual for these trucks? Or something similar.
Now I have a few more specific questions as it relates to a few issues I am having with my truck.
Both the front and rear sunroofs leaked just a bit a few years ago, which over time, with me driving with the windows open has head to my headliner beginning to fall. The dealer wants over $500 for a new one. No way I am going to pay that. Does anyone know of a good place to find a used one? My other alternative is to try and have it fixed locally.
My drivers side seat control failed on me at one point. Did ALOT of digging around on the internet and discovered that the fault is generally in the little switches/rockers inside the switch itself. I dissassembled and cleaned the switch and it fixed it. However, in the process I lost one of the little bitty rockers that go inside, so a portion of the power seat adjustment isnt working. Anyone know where I can find that little piece ( already checked the dealer ) or perhaps where I can get a used seat control box? A new one from the dealer is over $300. From what I understand rover uses mercedes seat control modules....but I dont know what years will fit mine.
Also, I believe I toasted a fuse for the passengerside seat as the controls to that stopped working immediately after I fixed the driverside. I found the fuses for the driverside power seat ( under the seat itself, and thats not in the owners manual ) but I cannot locate the fuses for the passengerside one. Any help?
I believe my VSS is going out on me, as I get the slight hesitation at highway speeds in overdrive. Dealer price = $130. They want $100 just to pull the codes from the ECU (check engine light is on). My rover is OBDII, I believe, so I would assume that anyone with a code scanner machine could tell me what codes the ECU is seeing. I've also recently read something about a box under the passengerside seat that should display the codes but i've been unable to locate it or verify that it does indeed exist. Is this true? And what might be the cheapest price for a VSS and where can I get one?
I'd like to remove my rear jumpseats as they are mostly worthless. Short of me just removing the innards of the rear interior, has anyone seen a write up on how to do that?
Factory stereo questions: If I decide to keep the car, the factory system will have to go. The door speakers have proved impossible to replace with anything aftermarket as they are a special thin design that fits in the door. Anyone know of either a speaker that fits or a good place to get a used one for cheaper? Also, i'd like to remove the 6 disk changer and factory head unit, but I cannot find a diagram for the pinouts on the unit. Anyone know if anyone makes an adapter harness for the amps and speakers or will I have to do it from scratch?
Thats all I can think of for now, if you made it this far, thanks for reading and sorry for my longwindedness . I'll do my best to contribute to the forums where I can.
Thanks!
Thanks!
