L
lacarruk1
I want to replace my shifter but do not want to crack the 6" plastic piece while removing it. Does anyone know how to properly remove the shift handle?
lacarruk1 said:I want to replace my shifter but do not want to crack the 6" plastic piece while removing it. Does anyone know how to properly remove the shift handle?
Matt_Grim2 said:I had the same problem when i replaced mine with a woodgrain shift knob about a month ago, i was told to twist and pull but apon doing so i cracked the shift knob, when i called the company of the woodgrain they instructed me that all you need to do is grab it, make sure the buttom is pulled out and pull really hard, that is what i did when i needed it off and it worked just fine, the key is to not push in on the button when you hold it...
lacarruk1 said:Matt- Thanks
Also - Since you have experience with this.... The Center console, I was able to pull that off no problem, but when I put the new APSIS center console (one that surrounds radio) on, it does not want to seal on the left and right side of the radio. Almost like too big of a gap there. I noticed there are these 4 slivers of plastic that get pushed in, I seem to be lining em up, but still not flush. Did you run into this problem?
Lastly -- In some areas of the new center console, I notice a little white haze on the wood grain. Not all over, just lightly in some spots. You have any issues or is yours perfect?
Matt_Grim2 said:I noticed the same thing as you, the original it was almost like it was sucktioned on to the console, but with the APSIS one it was a little to loose, what i did was bought peices of one sidded foam, that was sticky on one sick foam on the other, then some tape that was rubber on one as it looked to be what the original had one it and i placed it in certain spots so it would not rattle and would seal (you gotta get really thin tape)...
I did not notice the gap, once i lined the 4 metal clips up and snapped tem in it looked just like the original, you might wanna check that one of the clips didn't fall off as this happened to me and i had to clip it back on...
I noticed the white hase on one spot of the center console but i took some armorall cleaning whips to it and i have not noticed it anymore...
let me know if this helps or you need anymore help...
lacarruk1 said:Matt - 2 Questions
1. Did you ever receive your deposit back from the company?
2. Did you ever receive the cupholder custom piece back and how long did it take?
