Brillo Pad
- Joined
- Jan 2, 2008
- Posts
- 14
- Reaction score
- 0
I just purchaced my first Land Rover (2001 Disco II with 122K) and I'm having a lot if issues that I'm sure have more to do with me being stupid than it does with anything being wrong with the vehicle...
First and formost, I had to replace the battery right away, and about 15 minutes after doing so my service engine light came on. I took it to autozone and got these codes:
P0734 - "The PCM has detected an incorrect gear ratio condition in the 4th gear." Any ideas what this issue requires?
P0174 - "The PCM has determined that during testing, the fuel system for bank 2 was too lean. (Bank1 identifies the location of cylinder #1, while bank 2 identifies the cylinders on the opposite bank)"
Regarding the 2nd code (P0174), I did realize after the fact that I had filled the tank with regular unleaded gas. I've been driving a beat up Jeep Cherokee for years and it hadn't occured to me that nicer vehicles required better fuel. Could this be the cause of the problem?
Other issues:
I have the oversized Hella fog lamps but can't for the life of me figure out how to turn them on. I see the foglamp button on the console to the left of the stearing wheel, and also another foglight button labeled "2" but this doesn't seem to do anything...
If I pull out the factory stereo, are there RCA plugs on the back of the stereo that will allow me to hook up a subwoffer/amp?
Thanks for any help you may be able to offer. Sorry to be so needy!
Other issues:
