Key won't pop out.
butter73
Has anyone had a key that won't open up? I push the button and nothing. Any ideas?
dry_fly
sounds like the spring mechanism has broken, or there is some serious build up of pocket lint and crud built up in the hinge. I advise checking to see if there is something blocking the operation of the key, or resort to the spare key and keep this as the spare. if you are still under warranty and the spring is broken your dealer may be able to get you a new one otherwise they are pretty expensive for a replacement key. My dealer replaced both my key's when one of my remote batteries went bad and wouldn't accept a charge. (fortunately under warranty)
acsubie
having same problem.. is there anyway to pull apart both halves of the FOB to access the key portion/spring mech?
