Low Coolant Warning but...
grommet
Coolant sensor failure; common enough to have a tech article. Reservoir will get replaced/Easy fix. Happened to me at 18 months or so.
grommet
Yep, that's why I said the reservoir will get replaced. :D
roverman
nothing new here, mine went too. Of course, my new one lasted a couple days and it says I'm low again. Hope I'm not low because I don't see myself making a special trip to get a new one that doesn't work. Say that reminds me of my fuel tank recall that they replaced with a broken one....
askewed
TY! I'll have them address it next time it's in...
C
Cat
I had LR3 in shop last week for 30K service & had this warning off & on for several weeks prior to service. They "found coolant hose leaking at throttle body hose clamp. Remove and replaced hose clamp. Filled and serviced coolant system." No warning since...
Shark_LR3
Low coolant
I had this warning on my first drive with our '05. The reservoir is a design I haven't seen before, with multiple chambers. The level reading to me is a bit strange as a result. I filled mine, engine stone cold about 1" over the mark. Warning is gone.
