Land Rover Joe
- Joined
- Apr 10, 2011
- Posts
- 111
- Reaction score
- 3
Dear LR4 lovers,
Has anyone had the problem shown in my photo: “Camera System Fault”?
I have been having this problem intermittently for some time (~8 months); I believe it is basically a wiring harness issue (loose connection). I previously pulled out and cleaned everything in the rear camera assembly which solved the issue of the rear camera not working back in July. However, the issue arose again in September-October, at first occurring once-in-a-while and then later not working at all.
I have recently cleaned all the connections on the ECU under the driver’s seat; and today I cleaned all the cameras in the side-view mirrors (I have a separate post on the mirrors), but I am still having this issue—the cameras will not work. I assume that this fault happens when two or more cameras have a low voltage reading in the ECU. I have seen previously, when the camera's were dirty, simply a blue screen for the camera in question--but there was a signal. Now, nothing.
Difficulty with these systems where I live is the heat, dust, and corrosion. The low, dual-voltage (wave) for this camera system means it is not the most robust system in the truck and seems to be a bit finicky.
My next course of action is to clean the cameras (this includes the sockets) in the front bumper—but those may be a little trickier to get at. My truck is a 2010 LR4 HSE with full off-road package and everything but the in-car entertainment system.
If anyone with experience and insight could assist--it would be much appreciated!
Best wishes in 2013!
Land Rover Joe
Land Rover Joe
