- Joined
- Feb 8, 2011
- Posts
- 3,401
- Reaction score
- 92
Hey LR4Buckeye,Ahhhh very interesting, I will look to the manual for this. Thank you!
Just a few notes from my experience to add to George's comments...
1) You have to snap the body-colored fog light cap off, which was a little tricky at first. You will feel a little groove at the top of the fog light cap, then you use your finger to push in and then pop it off with firm / even pressure. You will not be able to fit more than just the tip of your finger in the groove.
2) Once the fog light caps are off, then I STRONGLY recommend you take some painter's tape or masking tape to tape up the holes before taking out the screws. You will see what I mean once you get the fog cap off. Basically I say this because there are holes where you could lose the screws easily and then they seem to go into the front bumper somewhere. I actually lost a fog cap clip in there and tried for 30 minutes to find it with no luck. Thus, tape up the holes so you don't lose the screws.
3) Once you tape up the holes, then you need to remove 3 screws (even though there are 4 holes). These are hexagonal (star) screws, not standard or philip's head. You will need a hexagonal screw driver that is a little longer since it's a tight space and it helps if it's magnetized at the end to hold the screw. You will see it's a rather tight space.
4) After you get the screws off (and put them in order) you can pull out the bulb unit and then unclip it and remove it completely. The bulb is really easy to install, just make sure you do not touch it at all.
5) Re-clip it back in place and then I tested it just to make sure it worked. Once it's clipped back in, then put the screws back in the order you took them out. Make sure you put them all back with even tightening. Once the unit is screwed back in place firmly, then you just pop the fight light cover back on and you are done!
Drop me a DM or post on here if you have any other questions or run into an issue.
Best of luck!
-David
