Thanks for everyone’s interest and attention,
So I have completed Phase I of the brake job.
Emurray,
Making a video exceeds my level of effort. However, I do have the “Haynes Automotive Brake Manual” which is a decent summary of brakes in general, as well as the LR4 workshop manual…which is of limited use but the diagrams explain what exactly everything is. What may be very helpful is the link at ************** Photo Gallery - Bodsy's Brake Bible (see forum page at
http://www.*******************/forums/f41/how-change-rear-brake-pads-lr3-58032/ ).
This is for the LR3…but it is basically the same from what I experienced and has excellent color pictures with fairly simple explanations for each step.
94speedster,
I purchased my OEM brake pads from British Parts of Utah [BPU]. They did not come with instructions but they did come with the bolts and anti-squeal (although I bought and used the Mercedes paste from BPU).
The part number for the front pads is LR032063 and they work like a charm; this is a new part number as Land Rover has apparently phased out whatever pads they were using before.
The part number for the rear pads is LR019627 and they are substantially smaller than the front (rear calipers have only one piston; front have two). Unfortunately, BPU sent me part number LR019618…which are the pads for the LR3 (and do not fit). !@$!%!. I didn’t realize this until after we had tried them and I called BPU to figure out what had gone wrong…and they had simply sent me the wrong part. There are apparently two slightly different sizes for the LR4 rear pads depending upon VIN, but either will fit. 19627 should be the right PN for 2010. So-holding off on the rear pad install until I get the correct part.
We flushed out the brake fluid…and it was pretty bad after three years (heavy duty use but very low mileage). The pads themselves have some life left…but replacement now is fine, a good PM measure and the breaking is now a lot tighter with new pads (ok…new pads on the front). But the fluid really needed to be changed. I used a French brand (Total) DOT 5.1 fluid. This is NOT Silicon (DOT 5) but the newest formulation of brake fluid (and highest boiling point yet). We will pull more fluid out when we do the rest of the work to see how things are doing. The experts tell me Silicon is a really bad idea for ABS. So far-everything is very smooth.
So for brake lines…I went and bought (after the pad drama) LR3 front and rear stainless steel brake lines from Race Inspired online, made by Stop Tech. They should fit…so we will try them out when everything gets here and we begin Phase II (change rear pads, change brake lines, drain/inspect brake fluid). I will let everyone know the results and post some pictures.
One thing I did not buy, but probably should have, were the pad sensors: they are pretty flimsy, really easy to break, and I will definitely change them out next time whether I go through the pads or not.
Also, I filled the tires with Nitrogen. I thought this was really pretty silly--someone talked me into it--but I really think it does make a bit of a difference: the wheels feel a bit firmer and don’t float quite as much, especially when they heat up on-road. I am told that a lot of folks are going to this for high-performance stuff.
Costs:
Front Brake Pads [PN LR032063]: $270 (BPU)
Rear Brake Pads [PN LR019627]: $90 (BPU)
Brake Anti-squeal Paste [RCBAS]: $8 (BPU)
Brake Fluid [DOT 5.1]: $60 (local supplier)
Front Stainless Steel Brake Lines [PN STO-950-22000]: $88.82 (Race Inspired)
Rear Stainless Steel Brake Lines [PN STO-950-22500]: $78.95 (Race Inspired)
Nitrogen: $25
Assorted Shipping: $40
Total Cost for this experiment: $665
Cheers,
Land Rover Joe
