Major Code problem
Bluebird
Just had Meineke install an Atlantic British Brake kit F and R Rotors and pads.
Went to pick it up and I have a major issues HDC code, no program available and the EAS won't inflate. \
Left it with them to fix. Any ideas?
They used the old sensors by the way.:confused:
morrisdl
Knocked a sensor out somewhere or crushed something with the jack. There are a ton of sensors on each wheel - ABS, height, TPSM, Pad wear, etc. or maybe use the air compressor at a lift point.
I just did this last week in <2 hours, with pad sensor replacements. Still easier than my Audi TT for sure, but mostly because the LR3 has less winters on it. Good luck! - I bet its the last LR3 they touch.
Hopefully they just ran the battery to the ground while doing your brakes. It could happen if they left the ignition in the II pos. and the auto lights turned on while the car was in the service bay.
Bluebird
ABS sensor wire got pinched by accident.
Meineke to pay dealer to fix.
Now that is a stand up guy.
Bluebird
Dealer charged me to calibrate emergency brake $104.00
So
Parts F and R $389.00 Atlantic British Kit
Labor to R/R $285.00 Meineke
E-Brake $110.00 Dealer
Total $784.00
Still better than $1200.00 from the dealer.:biggrin:
gvillalongo
