New to me... is this normal?
armozo
North West
Hi all, this is my third day with my new to me LR4. It is a 2010 HSE my 80k miles.
I am not sure if this normal so I figured I would ask you all. In the morning I feel like my engine is a bit too loud, especially when I am maneuvering my way around the neighborhood. Sounds like a low-end hauling when it rev's around 1500RPM.
Does that sound normal? I am not used to the rig and I think it is just what it sounds like.
Thanks in advance.
Yes, that's fairly normal when the engine is cold - the colder, the louder (RPMs stay well above normal even while idling in your garage)... :) The noise is compounded by the EAS compressor, which often also runs for a minute or two in the morning. After a minute or two warming up, everything usually settles down.
Bethesda, Maryland, USA
It almost sounds like you're describing the fan clutch issue. I had that in my previous LR4 and it sounded exactly like a super loud revving sound even at low rpm's. In fact, I heard it the first time as I was idling around a parking lot and it freaked me out. I thought the vehicle was stuck in a wrong gear or that it had slipped into neutral and I had jammed the accelerator. I pulled over and turned everything off. When I started back up again, it was gone. It only happened a few times and then miraculously seemed to be the rare issue that fixes itself.
Maybe you can get a recording of it from inside and outside of the vehicle. OTOH, it may just be a matter of degree and a sound you're not used to yet, like the normal warming up sound as umbertob mentioned.
armozo
North West
What you describe is what I experience... sometimes it just disappears. What did you do to fix it?
Sorry, but that's the frustrating part-- in my situation it just stopped happening on its own. I had that vehicle for at least a couple of years after the last incident and it never happened again.
anamorphic
USA
I too get this sound every once in a while and it happens at low speeds and definitely sounds like a large semi truck. Comes and go’s for me, glad someone else was able to describe it!
armozo
North West
It has been a few days now that I have not heard it. I think it is normal. I do like how it sounds.
toddjb122
It's how I know I'm driving a TRUCK!!
It also helps drown out the sound of the guy next to me in his Tesla, typing on his phone. So inconsiderate...
:D
Pfunk951
Umberto, isn't it true that when it is cold, the shift patterns actually change so that you stay in a lower gear (higher revs) until the block warms up?
Mike
If you ever have a chance to hear the insane decibel level of what we're describing, you would never mistake it for anything normal or gear-range-related. It sounds like a full cement truck in low gear going up a 45º incline. It is a full-on roar. I thought I was gonna see a rod or other engine part shooting through my hood.
Dandavies9
