F
frafael
guys here it's the updates:
I received my CD and check in ECU connector:
1) PIN1 - Actuator power - Comes up when brake SW is closed - OK!
2) PIN2 - Rs/Suspend - Level "1" (~11V) when SW in wheel is pushed - OK!
3) PIN3 - N/A
4) PIN4 - Set/Acce - Level "1" (~11V) when SW in wheel is pushed - OK!
5) PIN5 - Break Light - Level "1" (~11V) when break pad is pushed - OK!
6) PIN6 - N/A
7) PIN7 - Pump CTRL - "0" - Looks fine, I could not really test
8) PIN8 - ECU POWER - Comes up when I turn panel switch ON - OK!
9) PIN9 - N/A
10) PIN10 - N/A
11) PIN11 - Actuator Power ON - NOT Comes ON :c(
12) PIN12 - N/A
13) PIN13 - N/A
14) PIN14 - N/A
15) PIN15 - Speed Signal - Adequate (not real test)
16) PIN16 - Kline - Diagnostic - I don't know how to use
17) PIN17 - Valve CTRL - Leve "1" , Valve disable
18) PIN18 - Ground - oK!
So, this made me to beleive the ECU is not working.
I did open the ECU and identify the main components:
1) OKI 8 Bit CPU
2) Microchip Serial Memory
3) ELMOS ASICS, no documentation available
4) Low power 5V regulator 7805L
6) Automotive NEC SPDT relay
7) sort of smd resistors, cap, transistors and diodes.
I checked most I can (individual components), all power suplies, I reversed engineer the analog part and everythyng looks fine. The relay has I weird way to lacth when the SET SW is depress, I'd never understand why.
Looks like the PIN13 from ASIC is responsable to drain the current from the relay coil, and operate the relay but is not going to level "0". So I believe either the ASIC driver failed or the uP lost the program.
BTW, this relay is reponsable to connect PIN1 to PIN11, and power the actuator (pump em valves), I belive whenever everything works. I don't know if would happen with the car parked. With this relay opened the pump will never turn on.
Questions, where can I find a spare ECU to buy? I just found in England for $239, little expensive.
Any input?
3) PIN3 - N/A
6) PIN6 - N/A
9) PIN9 - N/A
10) PIN10 - N/A
12) PIN12 - N/A
13) PIN13 - N/A
14) PIN14 - N/A
1) OKI 8 Bit CPU
Any input?
