Noise when starting my Range Rover
Speed racer
Hi guys, I have just bought a used 2005 Range Rover HSE and every once in a while when the car is started it sounds like it has no oil for a split second or so. Like knocking, etc. then it just goes away adn sounds perfect and runs perfect.. To me it sounds like it is not getting oil, just for a second at start up.. Can anybody give me any ideas??? Thanks
Flush the oil and change it with a good synthetic... issue should go away.
l4flirop
The problem is related to three valves. First is in the oil filter housing its ball valve you need to run some seafoam or other vanish remover to clear the valve that is sticking,
Secondly there are two VCC Solenoids one on each bank of cylinders, You need a special socket from BMW to remove them and inside is a small valve which can be extracted with an 8mm Hex key inserted and gently wiggled out. Clean all sign sof varnish off of them both and reinstall. This should cure the problem.
rover13
Hey Guys,
New to the site. I have a 1992 County when I turn the key to open doors the locks keep going up and down all by themselves? any ideas?
Sounds like either the lock is bad on the drivers door (it controls the other doors) or you have a weird alarm issue.
Who is the one that is High?
