Range Rover Vogue 2009 L322 Electronic Parking Brake
Liam Britten
We have a problem with the electronic parking brake which has been diagnosed as being the control module although no code displayed, anyone got any advise on how to go about replacing it. Apparently there is a mechanical release facility but i cannot find it, no mention of it in the owners manual ? Any advise welcome. Thanks
What normally goes bad on the land rover/jaguar parking brake http://www.roverparts.com/Parts/LR019223G you can find it cheaper some places, but the reality is, it isn't cheap and there is discussion one way or the other as to what causes it to fail. Using it or not is the main thing.
Releasing it involves replacing or at least taking it apart.
Pg61
USA
Hello this is Peter in the USA is a repair kit for the gears on some of those models electronic brake systems emergency brake odometers by Jeff has the parts
Pg61
USA
I have a 2007 Range Rover HSE supercharged came in for a timing chain noise replace both time and change tensioner's and seals sounds great but since then we have an Excelerator problem from time to time won't excel rate and set a torque code replaced the throttle actuator Codes will clear go Drive it and they will come back checked all wiring check ABS codes check transmission codes no codes
gvillalongo
