Rear 12v socket no power?
Carl Long
Kingston, pa
Hi guys.
2014 LR4 HSE Lux. The front outlet, and 2nd row middle console both have power but the rear 12v cargo outlet is dead. I thought the fuse 55 controlled both middle and rear sockets but why would I have power on one and not the other? Any clues as to where I need to look now?
Michael Gain
Clarksville, TN
Check that the wiring harness is attached to the back of the socket.
Open the top and bottom lift gates. Remove just enough of the weather stripping to expose the length of the plastic panel that contains the socket ( between the panel and tail light). Pull the plastic panel inwards towards the center of the vehicle.
Two clips will pop and give you about 6 inches of space to observe the wiring harness, and fix anything necessary.
Vintage99
