I have a 2000 Discovery II with 54,000 miles. It has some issues with the central locking and the rear door not opening. climbing in the back, i found the previous owner had pulled back the upholstery panel at the latch. you can pull in out about 2" and push down the latch bar and the door will open. after that it will open from the outside as long as you don't lock it. once locked, it has to be tripped again by hand from inside. The central locking is a sometimes works kinda thing. it will usually lock everything, but not unlock. it will occasionally lock and unlock on all the doors.
climbing in the back to open the door is a hassle, any idea on a fix?
thanks Steven G.
thanks Steven G.
