Rear Locker
ishapiro
While one the same topic, I still have the original non locking rear diff and the two shafts with only 32kmiles on them sitting in boxes, waiting for a buyer.
Sent from my SM-N960W using Tapatalk
I think I have posted here couple times on this topic in the past already.
I have actually upgraded my 2012 LR4 with the original brand new landrover locking rear diff. For that I sourced:
1) rear e-diff
2)HD rear drive shafts (not a must)
3) ECU
4)used harness from RRS or LR3/LR4 with a locker.
5)IIDtool to update the CCF
6) 5 hours on the hoist at the local LR dealership
Everything except the infortainment works as expected.
What ECU does it require?
By "harness," do you mean the wiring harness that goes to the rear locker, or something more than that?
ishapiro
Ecu is the rear locking diff controller
The harness is just a short length that goes from the main chassis harness to the e-diff motor.
Where is that particular ECU located, and how did you power it?
ishapiro
It's right behind the rear left door opening and in front of the wheel well under that huge single piece interior plastic trim. It's next to the parking aid sensors ECU
Do you have a writeup somewhere on how you installed it?
So many questions. How does the ECU get info from the vehicle? How is it powered? Etc.
Is all that stuff there and unused on non-HD vehicles, or do you have to run your own wiring?
ishapiro
The main body harness already has all the connections. All you need is to mount and connect the right ecu. I leveraged a lot of info from forums covering the same retrofit for D3 (disco3.co.uk). I will check if I still have some of that somewhere.
ishapiro
Yes. Precisely! This one was what inspired me to do the same on my LR4. It took me a while to collect all the necessary parts from different sources at reasonable price though.
The only thing I couldn't completely resolve is my infotainment 4x4 screen doesnt show the rear padlock
ishapiro
Just to clarify, the infotainment doesn't show the rear locker but I can see it operational through iidtool
