I will add that you save the suspension calibration file so I have one for stock and one for offroad, you load it up when you want it. It takes about 2 minutes once you are hooked up which takes less than minute to do not counting computer boot time. I usually do it as I am airing down and done before my tires are aired down with my stauns.
You also have complete control over each airbag so you can raise or defalte any one bag regardless of the sensor not on the fly but if you get a problem you can bypass the system. I havn't tested it fully but you can also turn off the suspension ECU and just inflate all the bags.
