Removing a stuck hitch receiver?
tlt
This is coming soon, should be pretty nice.. PM me with your email address.
http://www. disco3. co.uk/gallery/displayimage.php?album=lastup&cat=11463&pos=0
toddjb122
Can you put the plastic cover back on behind it so it looks less like a hack?
Don't get me wrong, functionally if it meets the same towing requirements, it is great. Makes sense to have it up there. Looks slapped on but maybe if had a black powdercoat or something it wouldn't stand out as much.
tlt
That's was the plan, but it will likely need some trimming due to the top attachment point. If it works out, perhaps a custom cover would be a solution.
The one pictured is the Beta, mainly for feedback.
steveC101
I thought I'd revive this old thread to add a small solution to the stuck hitch issue.
As has been mentioned before when left on for a while the hitch will seize up because of rust on the piston locking mechanism. Even when the hitch is unlocked and the green knob pulled outward to reveal the red underneath the rust will still prevent the knob being turned because knob is too small to provide any leverage to free up the piston.
I had the problem today and found the solution in my small collection of plumbing tools: a PVC wrench. Simply use it as designed to loosen and tighten a PVC pipe connector and the leverage on the knob is enough to free up the piston without damaging the knob
While the hitch is off you can spray a load of blaster into the lube hole then move in and out to get it into the mechanism.
Here's the wrench: https://www.homedepot.com/p/Husky-12-in-PVC-Pliers-17PL0309/304217565
kels83
I can pull the hitch out, but the LR part which is supposed to drop down...nada. I insert the key, turn it, turn the big green knob, etc. As far as I know I'm following the instructions and doing what I've done before which caused it to drop in my hand.
Edit: Looks like someone already posted this tip.
Original:
The plastic hitch cover has ikea-like pictograms that show 1) key, 2) turn, 3) pull the green knob out towards the passenger (US) side. Are you doing #3? If the sticker fell off or if you tossed the cover there are pics on hitch covers for sale at ebay or I can probably take a picture.
