Speedometer recalibration with IID Tool
chakadog
Ditto! Thanks Jimmy I have also been trying to get the speedo right. I have almost the same tire - bit wider - but can't wait to try MSB IPC @ 30.
DrDan
Colorado
I just put a set of 18" Compomotives with Cooper ST MAXX LT265/65/18 on my 2014 LR4. I have the iLAND Diagnostic
tool. How to set the tire size for accurate speedometer readings is not described in the manual and so far in scrolling through
the menus, I have not found the proper place. Any hints? Thanks.
Jimmy Brooks
Pasadena California
Here they are. My tire size is 265/65/18 so if your tire size is different this most likely won’t be accurate with your real speed.
manoftaste
View attachment 11764[/QUOTE]
Sorry don't mean to hijack here, but are you really able to actually input the wheel/rim diameter into the vehicle' system?
And if so then should I have had my dealership update this data in my LR4 when I went from 20 inch rims (that came with my lux) to the standard spec 19 inch rims?
Because now I am wondering if the system actually takes the entered wheel/rim info into account (along with the tire' info) and adjusts certain parameters (maybe the suspension tuning, etc) due to the varying sidewall heights between the 20 and the 19 inch rim/tire combos.
I mean, the ability to feed the system this info is gotta be there for a reason, right?
DrDan
Colorado
Jimmy, thanks for the IID tool screen images. Your screen images look very different from my iLand tool, so I suspect you are using a different tool. Although I have been through most of the screens on mine, I don't see this. Which tool is this?
DrDan
Colorado
Jimmy, Thanks again. I just got off of a support call with iLAND and the iLAND tool cannot do the resize functions of the GAP tool. For basic fault diagnostics and resets it appears OK, but I will get a GAP tool. Lesson Learned.
gsxr
Idaho
Anyone know what exactly the IPC data field is?
