I have a 2005 LR3. The hose that drains from the sunroof is disconnected on the front right hand side. I used the technical bulletin attached an need help with number 5.
1. Turn the wheels to the fully left lock position.
NOTE: GTR lookup sequence is as follows:
GTR Home > NAS > Service Information/ LA LR3/2006> Workshop Manuals > Discovery 3/LR3
2005 Workshop Manual > Bookmark "Body and Paint/Body and Paint/501-08 Exterior Trim and
Ornamentation" > Link "Fender moulding (76.43.54)"
2. Refer to GTR Workshop Manual Section 76.43.54 and partially
release the left-hand front fender molding.
3. Partially release the left-hand front wheel arch lining, to gain
access to the roof opening panel drain tube. (Figure 7)
4. Verify that the drain tube is protruding through the hole in the
body.
5. If the drain tube is not protruding perform the following:
Workshop Manuals > Discovery 3/LR3 Workshop Manual >
Bookmark "Electrical Distribution/418-00" > Link "Central Junction Box (CJB) (86.70.56)"
• Refer to GTR Workshop Manual Section 86.70.56 and remove the CJB to gain access to the
sunroof panel drain tube.
• Connect and secure the drain tube through the hole in the body.
• Check the valve of the roof opening panel drain tube can be fully opened. (Figure 5)
• If the valve can not be opened, cut as required to permit full opening. (Figure 5)
body.
