Thoughts on these spark plugs?
M32H32IS
Texas
Pulled my plugs to chase down a misfire. I’m not sure what the coloration means, can someone help me figure this out?
Cyl 6 has a small amount of liquid that smells like fuel. I’m guessing I’ve got a leaky injector…
djkaosone
'11 LR4 HSE LUX 5.0L V8
SoCal
I agree @ktm525... Champions are terrible. I personally prefer Denso over NGK, but that's my personal preference. I like the Denso Long Life, but you'll have to gap them to 0.040". Otherwise, they're pregapped.
Get new plugs in and see if the misfires go away.
M32H32IS
Texas
10-4 I’ll order a new set and report back after some driving.
M32H32IS
Texas
Should I reset adaptations with my GAP tool so the CPU “learns” the new firepower?
While not excessively difficult, the spark plug job on an LR4 isn't exactly a breeze, either. Boggles my mind that someone would go through the trouble of changing the plugs but use the wrong parts.
M32H32IS
Texas
A lot of the work done by the shady car dealer who sold this to me was mind boggling.
How many miles on your rig? Those plugs have been in there awhile and we know they are at least the second set (not original).
powershift
Nevada
They look good. You want them to be tan as that indicates the correct air:fuel mixture. If you smell fumes there is a leak somewhere.
djkaosone
SoCal
I would check out the Live Values on STFT and LTFT on both bank 1 and bank 2 after swapping in the new plugs. IF both banks are really off and/or +/-10%, then yes I would Clear Adaptation Values to reset the ECU into learning mode.
I personally would Clear Adaptation Values when changing sensors like O2, Map, Maf, Crank position, Throttle position, or ANY sensor that has to do with timing and/or fuel curves. Reseting the ecu will force relearning fuel curves over a few drives and few days.
