Tune up help
Brownie92
I have searched the forums and couldn't find the speciffic answers so here is my post.
2000 DII with 110K, I bought this used with 80K on it and besides regular oil changes and one intake seafoam treatment I haven't done much too it. I am unsure of its service history and so I am planning on a "service day or two" once it warms up. I don't mean to start a this oil, spark plug, plug wire etc.. is better than the other. I want to keep the truck going smoothly. I don't have time to do any off-roading :hmpf: But I do occasionally pull a 16 ft boat. I was planning on:
Transmission fluid and filter
Plugs and wires
Differential fluids
Transfercase
A few questions,
How in the Hell do you get to the plug wires on the back of the engine (bosch engine)?
What are the "recommeded" fluids for the Trans, Diff, Transfer case?
Do all Discos of this year range have the same ZF transmission?
Who has the best prices for Trans parts and plugs/wires?
Thanks in advance
Disco Squared
How in the Hell do you get to the plug wires on the back of the engine (bosch engine)?Changing the plug wires can be done with some patients but is definately a pain. Removing the secondary air injection manifold helps a little, it's the stainless steel tube at the back of the engine. Also, buy some quality wires that will last a long time so that you won't have to replace them again for a while, Magnacore is good.
LUBRICANTS AND FLUIDS
Engine sump
Oil to meet 5W/30
API service level SG, SH or SJ 5W/40, 5W/50
10W/30
10W/40
10W/50
10W/60
Automatic gearbox
ATF Dexron III
Transfer gearbox
API GLS MTI fully synthetic 75W/90R
Axles
Power steering & ACE
Texaco Cold Climate PAS fluid 14315
NOTE: Recommended oils are complete in themselves and additives should not be used.
NOTE: It is essential to change oil much more frequently if the vehicle is operated under
severe conditions, especially if deep wading is carried out.
Do all Discos of this year range have the same ZF transmission? Yes
Who has the best prices for Trans parts and plugs/wires? Not sure about the best, but here's a start:
http://roverconnection.com/
http://www.roversnorth.com/
http://www.roverparts.com/
http://www.discountbritishparts.com/
Good luck:hello:
Brownie92
Thank you very much, that is exactly what I was looking for. I knew I could count on you guys.
Thanks.
tflint2112
