Turning left...hearing some sort of grinding??
azaky
Over the last couple of days, when I make a left turn under some power, I am hearing some grinding, like something in the front right tire area is grinding with something. I had all the upper/lower control arms done about 20k ago, I only have big BFGs and the rod mod.
Any ideas?
Thanks for the help.
nwoods
If its at full turn, its a simple rub point at the steering stop. This used to be a common fix that a dab of grease will resolve. There used to be a write up and photo on www.**************, but I haven't been on there in a long time and wouldn't know where to start looking
azaky
Thanks guys,
Now I am starting to hear a little knock. Whenever I turn the wheel quickly. Any idea how to check wheel bearings?
Thank you.
ssloane
jack wheel off ground and see if it jiggles back and forth. changing my wheel bearings this weekend
Disco Mike
Pull both front wheels and inspect the front brakes and bearings.
not necessarily...not if ONLY when turning.
