witecaphyr4u
- Joined
- Jan 19, 2006
- Posts
- 23
- Reaction score
- 0
So I went driving though some water holes today and ended up stalling in one of them. (2' deep) I got it started right back up and pulled out and it died again and would not start. After sitting for a bit, I finally got it to start for a couple sec but it sounded really rough. I pulled the maf and there was water under the maf in that little bubble on the intake. I started it with the maf disconnected and still ran really rough and it ended up throwing a code.
So, i got it home(idled all of the way) and it still will idle OK but when you rev it, it tries to stall and when you back off the throttle, the idle jumps up for a second. You can ocillate the throttle and get it to climb to around 2500rpm or so but if you hold it, it bogs out. Its been sitting for a few hours and I started it up and still idles, but will not rev. I noticed a hissing sound that I believe to the the throttle bypass cause you can pinch the hose to the bypass and it changes the sound, not sure if this is normal? The CEL cleared itself and there are no warnings now, but it still will not run right. Any ideas?
My thoughts are fuel/water in the gas, since it idles ok, I think spark ok on all cylinders cause it doesnt sound like its miss firing. It only has a 1/8 tank of gas and I just added 2.25gal fresh gas, but no change, so Im at a loss right now. Im going to let it sit over night and see what it does in the morning. Any ideas would be helpfull.
CSeel
CSeel
