'05 LR-3 A/c drain lines. WHERE ARE THEY???
rlogan75
If anyody has pics of the location of a/c drains on a '05 LR-3... pleeeese post ot send a link or something... Ive looked 3 times and still can't find them...should i be looking for a tube hanging down??? :confused:or is it up against the undercarrage??:confused: Im at my wits end...it looks pretty ghetto having a shammy on my passenger floorboard... and with the Texas heat...a/c is a must have... :mad:
USAFbuckeye
From the interior you have to pull the courtesy light panel down. It pretty simple. Just remove the two screws from each panel on both sides. Pull them down and disconnect the courtesy light. Once you have the panels removed look under the center console and the places that are now visible since you removed the panels. You should see a rubber tube connected to a metal one. Pull the tab and put a coat hangar or something else down the tube to release the block.
Going from underneath is a bit more difficult unless you have really thin arms. If it's real backed up and your underneath you will probably get really wet.
Sorry I don't have any pictures but if you go from the inside it's much easier.
