brake light on 2003 disco
pjvarc
my brake light came on and was recently advised its electrical short in my instrument cluster panel i need to replace the entire unit.
my mechanic advised me the brake light on is not related to my shutter valve or low brake fluid or even replacing brake pads. does this sound right?
brake light on and needing to replace the instrument cluster?
now, i since i have owned my truck in the last four years i have never replace my brake pads. i know my rear pads are not oem land rover pads cause they are starting to make noise. my mechanic told me they are fine but i went to a local dealer and was advised i need to replace my shutter valve,sensor abs plus the front right wheel speed sensor and rear brakes. does this sound more correct than replacing the instrument cluster?
p
Start over, what brake light?
Then send me your number and I'll walk you thru how to fix it with out replacing things.
STQAddie91
