Disco 2 coolant flush
clieman
Hello all!
Can anyone tell me the best way to go about flushing the cooling system on an 01 disco 2? I cant find the drain plug (I assume there has to be one). Any help would be appreciated. Ive read here that on an older disco you have to remove the bottom hose. Same for newer disco 2's? If so, which side is the correct hose to remove on?
P
penguinpwrd
You must remove the hose. The bottom-most one is the proper one to remove, which should be the hose on the passenger side. Ensure that you remove the cap prior to doing this - and even though it's common sense - make sure the engine is completely cool (like, sat overnight) before attempting this....
