Disco door lock question
tracyfsu
Hi,
I have an '03 Disco with about 77,000 miles.
Does anyone know what would cause both passenger side door locks to stop working simultaneously? The only way I can unlock those 2 doors is with the interior lock button. The lock knobs don't raise though until I physically pull the interior door handle. The exterior door handles will not open the door at all.
Tracy
Tallahassee
I would first check to make sure they are getting voltage to make sure it isn't just a bad ground going to those two doors. The odds are high that they both went bad at the same time, but it is possible.
jc316
If you can get the doors to unlock via the interior button, then I'd check the fuses. I'm having issues with my doors as well but they do not respond to the key or the button. I have to manually unlock them from the inside. They do respond to the key when I lock it though. My issue is with the lock actuator. I'm actually trying to get those out now. Having a bit of an issue though.
BCNJ
