Oil Leak
norm
Hi all. I have a oil leak on the L/h side front wheel on a D1. Can some please tell me which seal i need to replace. thank you
That is probably the Power Steering fluid leak that is way too common on LR's. Replace the clamps and possibly the low pressure hoses, but the factory clamps suck.
Inside of the rim could still be the PS hoses, or you are leaking swivel grease, or worse the last person to change your oil didn't have a splash pan up to keep it from covering your rim.
BCNJ
