overflow bottle keeps leaking around the cap
godawgz7
I have a 2005 range rover. The resivoir bottle keeps leaking around the lid. i have replaced the cap and tank but it keeps leaking and my light comes on saying check coolant. I dont know why it is coming out i put bmw blue antifreeze in it and it put the correct amount. I am very frustrated and need help before i cary it to gwinnett place land rover.
socalrovershop
possible crack in the reservoir. possible excessive pressure in system causing check valve to open.
godawgz7
resivoir
whta could cause the extra pressure? there is no visible crack in the tank.
godawgz7
Tank
i just cranked the car and took the cap off and it was barely spitting any fluid into the tank. does this mean i need a new radiator?
hayawan
It sounds like the bleeder screw is loose, it's next to the cap, that's where the coolant is leaking from. Just tighten it up a little, but be careful, it's plastic.
godawgz7
Cap
The Bleader Valve Is Tight. I Just Replaced The Radiator And Thermostat. When I Refill The Radiator Fluid How Do I Release Any Air Bubbles?
hayawan
Replacing the radiator and the thermostat is good preventive maintenance, but that does not address the problem, unless you are having/had overheating issues. If it's leaking at the reservoir cap, I would suspect the reservoir has a crack or the cap is defective, I would replace both. Also check the hoses that connect to the reservoir.
This is how I refill my coolant system (in this order). Fill up the system with a pre-mixed 50/50 (BMW coolant & distilled water). Start the car, turn on the heater and set it to max, open the bleeder screw half way, watch the coolant level in the reservoir and keep adding coolant, keeping the coolant level at the neck of the reservoir. As the engine warms up, you'll see coolant with bubbles flow out of the bleeder screw. Tighten the screw after you get a steady stream of coolant coming out (no bubbles). Make sure again the coolant level in the reservoir is ok, replace the cap and allow the engine to reach normal temp. Turn off the engine and let the car cool down, check the level again, add enough coolant untill the level reaches "max" (indicated by that float stick) make sure you don't over fill. You'll need to check the coolant level again after the car sat overnight. Keep checking the coolant for a couple of days.
godawgz7
cap
the reason it is leaking is because it is boiling out... it is at gwinnett place land rover now. could this mean i nead a head gsket?
PE_in_UAE
