Please help me Transmission faults
koffeetemple
Well folks see if you can help me with this
I have a 2009 FFRR Vogue with 3.6L TDV8
It is coming up with the following codes
P0730-00 Incorrect gear ratio
P0735-00 Gear 5 incorrect ratio
U0401-94 invalid data received from engine control module/powertrain control module
U0402-94 invalid data received from transmission control module
U0416-94 invalid data received from vehicle dynamics control module
U0403-94 invalid data received from transfer case control module
This only happens when towing (we tow a horse float 1.6 Tonne), with out the float no problems
It goes into limp home mode and comes up with a transmission error saying limited gears
When we use the manual selection and keep RPM up around 3000 - 3500 no problems
Could it be the Torque converter, valve bodies?
I have had the oil changed and it was very dirty and when this started i had the fluid changed a second time
Please help if you can
Thanks
Damien
Make sure the transmission fluid is full and have your battery checked.
jimbiram
Battery problem. My battery got low and I stored all the same codes.
Every Day is a Good Day Surfing...Some are just Better Than Others
PE_in_UAE
