Range on keyless entry
Battery is rarely the problem. Mine only works about 3-5ft from the truck whether I wear a foil covered hard hat in a lightening storm or not. There must be a fix for this because it used to work at about 10-15ft away and certainly must have worked better when the truck was new. The LR3 remote works from inside a building and 40 ft away, no line of sight required. Shoot even the Classic works from inside my house 25 ft away.
Brownie92
There would have to be a small "antenna" inside the key fob...I wonder if you could solder a wire from that part of the circut to the head of the metal key:confused: (keeping the wire inside the key fob of course) Thereby making the key the larger antenna. Someone else can try it, I only have one fob for my truck. :proud:
Tumbler
