RR AFS Llocation
waspjr123
Anybody have an idea where a afs is located on 2007 rr fullsize l322 engine. Thanks.
roverman
and you might want to try the ffrr section. Personally I'm guilty of not knowing what an AFS even is.
range rovers dot net might have some good info for you.
Good luck!
quick google search, it looks like it's a thin rectangular item, located right under the main headlight access point on the rear of the headlight assembly. It looks like it even says AFS module on it. If that's what you're looking for.
