U
Unruely
This has been a continuinig nuisnce of a problem with my '94 D1, 157000 miles. It runs fine during normal driving, the problem arrives when I stop for a light or stop sign. After sitting at idle for about 15 seconds the rpm's will drop to about 500rpm and run rough like it is only firing on 6 or 7 cylinders. If I try to pull out at a slow steady normal pace it acts like it doesn't want to take gas, kinda of sputtering and shuddering, etc.. If I shove the gas pedal down hard it will take off and run great until I must stop again. If I am driving thru town when this is going on, it will also start to get hot.. Again at normal highway driving the temps are fine. Here are the list of things checked, changed or replaced in the past year or so, some where in an effort to solve this problem. The fuel pump, fuel filter, injectors, O2 sensors,, complete tune up with new cap, rotor button, wires, etc.., coil, MAF, cleaned stepper motor, and other items, not counting the transmission and Tcase.... I have done some testing and have noticed that if I unplug the MAF it will run much better, the RPM's stiil drop some at a stop but will take gas without putting the pedal to the floor. This was my deciding factor for changing the MAF, but it does the same thing using 3 different MAF's. The only code I get is "47" refering to the O2 sensor which have both been replaced?? I have also checked the fuel preasure both before and during a time when it is running rough and it remains steady! HELP.
Martin
ps: Hey Joey..
Martin
ps: Hey Joey..
