td4 with a faulty driving me nuts
jimjam
hi new to this forum and in need of some help with a td4 fault , the engine has started smoking , it only smokes at 2000 2500 rpm befor and after that its find , the smoke is white and smells ( unburnt fuel ) the freelander runs fine pulls well ticks over well , its been checked for fault codes and is ok ,so far i have checked and changed with new parts , fuel filter , mas senser , air filter , boost controler , manifold gasket , injectors , manifold pressure switch , turbo hoses have been checked not replaced , not realy sure what to check next really stuck , i have looked at a frends td4 i disconected his manifold pressure switch and it did the same as mine so i replaced mine and still no luck , if you realy drive mine hard govener in every gear it will clear with no smoke at all turn it off and leave for 30 mins and the faults back , could it be a turbo fault or intercooler ? seems to pull well , any help would be really apprecated , forgot to say cat has been removed and the erg valve
STQAddie91
