Vacuum hoses
C
charlie
Hi there ,and G'day from down under, great site, with heaps of information but I have a drama and can't find any info on this subject.
I noticed I have two pipes/hoses missing form my vehicle, 1998 Disco V8i , despite looking at the manual I can't fine where these hoses are suppose to connect to? can anyone tell me or have a diagram of where the vacuum hose from the fuel pressure regulator go's to? I can't seem to find where this fixes to, also the cruise control vacuum hose is missing off the actuator, can anyone shed som light as to where the pipe is supposed to go to?
Cheers
Charlie, Perth WA
I just found a black pipe which runs across the firewall, attached is a T piece, which I believe runs to unit under the right hand side headlight area, I think this pipe connects to the actuator, still need to find where the pipe runs to from the feul pressure regulatore though, cheers.
You are correct on the Cruise line.... If someone else doesn't answer, I will check my Disco this afternoon on the other line.
C
charlie
Thanks so much, a friend has the same model as mine but he says his vehicle does not have this second pipe? cheers anyway Joey.
BCNJ
