Will these fit the LR3 SE?
T
Tomasz
Are you in UK? They should fit. But I recommend checking with a reputable wheel shop. I understand that Land Rover has very stringent strength requirements and many wheels do not pass. OZ Canyon ST in 20" size appear to be fine.
L
Landub
re
Living in Ireland.. I was thinkin of the recommended tyre ToYo Proxes S/T for this wheel. Are the OZ as good?
T
Tomasz
Herer in US we have a reputable tire and wheel shop - tirerack. They approved the 20" OZ wheels, but no Millie Miglia wheels. I can also tell you that the MM wheels are one of the softer out there. I would skip. Do check ou tthe OZ Canyon ST in 20 x 9.5 size. If you do go 20", please let me know what size of tire you get. I am interested to see if 275 or 285 would work properly.
roverman
According to the thread about tires, Nomad232 put 285's on his truck and said they work fine.
Paul p
