would 305/40/22 tires fit under a stock disco 1??
N
nick325ic
I know the inch. height would be 31.61 inch. would that fit under it??
D
disco1
I doubt that you would be able to fit them. Firstly, you may have to raise your vehicle, and, possibly need to trim. Secondly, you would need to find a set of 22" rims that are at least 10" wide. Thirdly, even if you got this far, you would have a reduced turning circle due to rubbing.
If you go ahead with the install, I'd love to see some photos.
ColeCam
I don't think it would fit either, mainly because of the width...they would be sticking out the sides really bad, that is more of an escalade/h2 size isn't it? Lift or no lift, with a rim that is 10+" it isn't going to fit. Or put a different way... Of course they will fit but you will only get to drive straight forward and backward :) Not to say there isn't some way to fit 22s just not that tire...
STQAddie91
