Brake Light (Tail Lamp) Issue
richpike
Hi Guys,
Long time, no post. We recently noticed that our rear brake lights are out on our 2005 LR3. I bought new bulbs - didn't help. Checked all the fuses I could think might be a culprit (fuse slots 15, 22, etc) - they were all fine. Here is the weird thing - the center brake light still works (the LED one up top).
Anyone run in to this before? Is this a brake switch issue? We can still shift it out of park and the center brake light still works, so I'm guessing that isn't it, but I could be wrong.
Thanks in advance!
Rich
angasreid
Do you have the trailer wiring harness installed? If so perhaps something happened there?
richpike
Good call - we do. I looked for the trailering fuse block (which the manual claims is behind the lefthand side rear access panel, but I was unable to find it). Fortunately our dealer (who is fantastic - I highly recomend Red Noland service to anyone in the Front Range) is able to get us in this morning.
I'll let everyone know what the issue was, but I'm beginning to think you might be right (something in the trailer wiring).
-Rich
jjvd21
Are you checking the top bulb in the lights? Believe that's the only one that lights up during braking.
Team Jeff
Check the bulb socket for 12v & also the grounds - not sure where the closest gnd is, but it may be common for the brake light bulbs.
