Thinking of Upgrading from LR3 to LR4
grecoroman
I get it between 25-35mph and also around 55-60. Dealer hasn't been able to find anything. Parts of me blames it on the spacers but it may not make sense.
Nah, that sounds like the bushings are shot on the control arms. It's the most common LR3 issue and the LR4 shares the same parts.
samcarloso
after reading all of your comments it looks as if those with a shimmy are 2010 models. If you notice the shimmy more apparent when you take your hands off the steering wheel then it might be a current TSB which requires a new steering gear and steering wheel. Also you might notice a squeal when accelerating around 2,200 rpms. I had this TSB done on my lr4 and since then it has been smooth sailing.
grecoroman
You are absolutely right: http://www.landroverworld.org/forums/showthread.php?t=22431
I'm going to add this TSB to my LR4 Buyer's Guide Checklist!
AxelR
Hey guys,
Do you happen to have this TSB number.
My truck has been developing a slight noise at the steering wheel in the last few weeks.
I mentioned it to one of the techs who seemed concerned but told me they would check it next time I go in for service.
This truck is awesome but the problems that come attached to it are never ending it seems.
Thank you
epiclr4
Very true! I love it when it works but life is miserable when it is in the shop!
samcarloso
Hey guys,
Thank you
is that noise (squeal/whine) from your steering wheel more noticeable with a hard acceleration?
Lone Star landy
58k on the odometer
1. Front passenger wheel bearings replaced. Approximately 50k miles.
2. Interior LED light in drivers door went out, replaced. Approximately 30k miles.
3. When my wife was driving down the highway, the entire Brake light housing above the rear glass came unglued and was hanging down on the rear glass by the wire. Apparently its attached to the car only by adhesive, so the dealer just re-glued it. Approximately 42k miles.
Those are the only problems we've ever had.
All repairs done by Land Rover Southwest Houston.
We really love our LR4.
grecoroman
58k on the odometer
Not bad at all. I'm also located in Houston!
helge
