Mainlander
The rear hatch switch does not release/open the rear tail gate for my 2010 LR4. When I use the trunk button on the keyfob the upper tail gate opens, so seems the actuator/cable system is still working. Before I go and replace this switch is there potentially any other cause or tests I should do? Also, do the LR3 switches fit the LR4?
I found two part numbers for the switch: LR015458 and LR071911. Are these part numbers interchangeable?
