Yup, I have it and used it.Land Rover has a special slide-hammer tool they use to remove the injectors.
The fuel rail sits on top of the top fed fuel injectors. It is firmly stuck on it and takes a lot of force to remove it. The scissor jack trick removes it really easy and takes less than 3 minutes to setup and remove.So is the fuel rail stuck on the top of the injectors or when you are pulling you are pulling rail and injectors?
I've previously replaced it and other things less than 6 months ago like the thermostat, water pump and the plastic piece behind it, spark plugs, ignition coils, belts, alternator, cooling pipes, map sensor, maf sensor, and pretty much everything around the engine. This would be the first major project.Replace the crossover pipe as well while you are in there
Interested in renting it out?
Yes for sure!Interested in renting it out?
