Whiiiiiiiiirrrring Sound VS. RPM
nymoto
Hey all - listen to this clip. My truck sounds like ****. Works great but wow. I have done some internet sleuthing and some say it’s the drivetrain but how if it increases with the RPM’s? Any insight would be super helpful.
Thanks again crew!
- Adrien
IMG_1799.MOV
nymoto
How do you post a video? I have the “vip” whatever plan. This is infuriating.
nymoto
Thanks - here it is. For the record the app should be able to upload and handle video. Whatever.
Tapps33
Bath, Maine
Hmmm....don’t know that I’ve heard that one myself. I’m assuming it’s coming from the left side of the engine? If so, it resembles a power steering pump that’s growling, and that is indeed located over there.
Is the AC off? Is it throwing any codes? Do you have a discrete scanner to pull all the codes, not just the MIL codes?
I’ve got a 2010 LR4, and I think my power steering pump lines are starting to leak a little, and I don’t believe there’s a “fluid level” sensor in there. I’ve had to refill my reservoir once or twice. But, if yours has run low and stayed that way for a while, it could be your pump is hot.
I could be way off as well....it’s hard to diagnose with sound only. But at least it’s something to check.
SkyTree
Southern California
Not saying this is the issue, but I had the same initial thought as @Tapps33 that it sounds like a power steering pump.
A couple years back, my Ford Explorer (also a V8, 4.6L) sounded exactly like that when turning the wheel (moving or stationary), and as we know these 5.0L V8 LR4s are basically luxury Ford Explorers on steroids with all the FoMoCo (Ford Motor Company) parts they have inside.
This is not a bad thing, imo, as it allows us to utilize the wealth of Ford truck knowledge out there to help diagnose our Ford design-era Rovers as well. Not an exact science, but helps us move in the right direction toward possible fixes.
In the case above with my Explorer, a power steering fluid change and bleeding the air from the system fixed the issue and there was no more sound.
It may be something that simple, hopefully.
SkyTree
Sent from my SM-G975U using Tapatalk
Tapps33
Bath, Maine
Yeah, @SkyTree sounds like he’s on to something. If there’s one thing about these trucks that never ceases to amaze me, it’s the ability of a fluid flush and replacement to bring systems back to life. I’ve had lots of other vehicles and really I never noticed a difference when I would flush and replace fluids........but on the LR4....different story.
SkyTree
Southern California
Thank you, and ain't that the truth!
