Thermostat outlet hose
DonC
The Woodlands, TX, US
I found this little gem after having to do a water pump replacement on a new to me 2017 D5 Lux with the SCV6 that I purchased the first of Dec. I was in a bit of a rush to get into a vehicle since my LR4 was just in a hit and run with a underage driver (and my D2 had just sold the week before). I am still waiting to see if that will be a total write off. Anyways bringing the D5 home the water pump started failing so I went and did a replacement. Putting it back together again this little pipe broke and I started looking for a replacement when I found this. Hopefully it can help someone here with a LR4 that might find themselves with the same issue. Beats replacing the entire hose if is it not needed plus it is made out of brass.
https://www.ebay.com/itm/265027875966
Did the brass pipe work? You sir are awesome. I had to buy a complete LR assembly to get the plastic pipe and then franken modify my existing system to make it all work... Where were you 2 weeks ago lol??
DonC
It did. Replaced just this part and no issues with it. Exact same size as the part it replaces. I wish this had been available earlier this year when I changed the water pump on my lr4.
Anyone know if the LR coolant is okay on brass? I think dexcool will corrode brass. Not sure if anything would come of it in this particular application (passage doesn’t appear to be small enough to get clogged with corrosion).
lostmybearing
