Is this a bad tie rod?
gillygong
Pasadena
I've been getting what feels like a lot of steering shake when driving over bumps or rough road. No shake or wobble or anything when driving at any speed on smooth roads. More like the steering jerks left or right when hitting bumps.
I tried swapping front and rear wheels- no difference.
Today I lifted the front end up, and didn't see anything amiss- the rubber boots at both tie rod ends on each side look good. I then tried rocking each back and forth holding at 6 and 9. I didn't feel any obvious play on either side, but there is a loud clicking/clunking sound which you can hear in the video below. I think it's happening on both left and right but more so on the left so I could just be hearing it from the opposite side when rocking the passenger side wheel. It sounds like it's coming from the inner tie rod area as opposed to near the wheel.
Could this be a bad tie rod or something else? What else should I do to investigate? Is it worth replacing the tie rods as a test?
2013 LR4 135k miles
Jimmy Brooks
Pasadena California
2013 LR4 135k miles
Have you done lower control arms?
Rberkel
California
Sounds like bad tie rods. A common wear problem. Make sure you order the correct ones for your vehicle. They changed the thread on them.
See this video:
gillygong
Pasadena
Just had new tires put on and had the shops mechanic look at the suspension. He said nothing looked bad but need an alignment. Going to do that and evaluate
tflint2112
