drive shaft
clydon
lately in reverse my 97 discovery has been been feeling rough, almost like something is grinding. also when on the highway if i release the gas too abruptly there is a clunking noise. i got an oil change today and was told that where the drive shaft meets meets the rear drive shaft the joint is on its way out, not sure exactly what its called. anyone have this problem? is it an easy fix, something i could replace myself or is it an inexpensive repair?
samroverguy
You can do it yourself. I did one once and I think I got the driveshaft rebuilt by a local guy. It was not terribly expensive, but it was a little Saturday job.
joey
I believe you are talking about the donut looking part, it is called the flexible coupling... this tends to go bad and cause the issue you are having... I would also look into changing the U-joints while you are at it.
wolf
Joey is correct - I just had mine done while down in LA - 2000 miles from home and my tools (ouch - not cheap)! but if you want to have real fun - just wait for the rear-end to go and then replace the whole thing with an ARB air-operated locker rig; they are amazing!
