Stock Aluminum Crossovers?
16FujiDisco
Nashville, TN
So I was watching this YouTube video of a 5.0 SC engine teardown
At the 8:57 mark you can clearly see aluminum front crossovers, and at 39:59 you can see an aluminum lower portion (rear at 10:05 is still plastic). That being said, this engine is clearly stock but has metal pipes, is there already a stock FOMOCO part that could be used instead of the plastics? or does the 5.0 SC have different sized pipes that wouldn't work on the 3.0 SC? They look the exact same visually. Have we covered this before and I just don't remember the discussion with all the times it's been covered?
Also this video is a great view of where everything is and how they are attached/removed for reference
