Mudquest
- Joined
- Oct 18, 2006
- Posts
- 75
- Reaction score
- 0
My automatic trans on the 2000 Disco II has just starting acting rather strange. When shifting into the next gear, it hesitates, then the trucks sort of bucks or lurches forward a little, and then the gear engages. It's happened a few times last weekend, primarily when the trans is cold. Also, when approching a stop light, I can hear a small 'thud' from what I believe is the trans downshifting. Maybe not. The idle then reduces to a point where the engine just stalls out. I've only had this truck for about two weeks, so I do not know the history as to how well the fluids were maintained. It's shifting seems sluggish and odd though.
I've been told that changing the fluid on a 'testy' trans can cause more problems. Should I be concerned? Or will a good fluid change be exactly what this baby needs?
I should probably check the AFT fluid color to confirm it's status. Any advise is appreciated.
Cheers,
J
Cheers,
J
