2008 LR3 hatch will not open
The service manager up there, Rahim...is pretty much the $hit. They're having a customer appreciation BBQ/Service Clinic next Saturday (3/12). You should drop by and poke around....
mattroark
barry3bail
I followed the directions to fix the latch on my landrover that I received here. Found the latch, moved it back and forth and the top hatch opened right up. I was amazed at how simple it was. The hook that goes down in the hole to open that hatch broke off. Tommorow I will continue to fix and let you guys know how I made out.
Thanks to all. You guys saved me about 300 dollars.
barry3bail
I can hear the lock electronics releasing but it is still jammed shut. Is there anything I can do, without taking it to the dealer?
Mattroak if you do not mind trying yourself, you will save yourself some money. i followed the instructions word for word, and my hatch is open and I know how to fix it. LandRover dealer quoted me 450 dollars. After I opened the shaft I thought about the money I would throw away for something so simple.
barry3bail
One thing the guy forgot to tell you was you have to get a 1/2 in wrench and turn that cable to the bottom lift until it is all the way down. Man that was some critical info to leave out. messed around with that thing for 45 minutes. Thank God for those photos
barry3bail
hey guys I follwed the directions and I repaired the liftgate. opens up just like before. I want to thank the gentleman who posted those instructions for all to take advantage of ///Thanks
barry3bail
Just wanted to say that the bottom lift opens automatically once the top lft gate has been opened. If it does not you need a new button. That the little white button that you press to open up the bottom lift. Cost about 45 dollars but easy to install
Ryck1494
Encountered the same problem with my 06 lr3. Is the spot where the screw driver needs to go located higher or lower than the hole you are working with? I understand that it is to the left, but is it above the hole?
gtc
I assumed it was right in the hole - however, I never managed to make this work. Instead, I popped the back off of the actuator housing and just pulled on the cable - effectively doing the same thing. It's awkward unless you have small hands, or unless you cut the cable outside of the actuator housing and replace it when everything is opened up (which seems more common then just pulling on it for some reason).
I tried for about 45 minutes /w the screw driver and had no luck at all - thus the alternate route...
Ryck1494
OK.. well i have tried inserting the screw driver in the hole and it seem shallow and i am unable to stick it in further. The hole that i am attempting to put the screw driver in is directly above the "larger" area in which you need to work.. so how did you pop the actuator housing off?? is it above the spot that i am working with... and are the large black wires electrical or is that the cable??
Disco2TrailEdit4
